Skip to content
Unreal Engine SDK
This SDK is in Beta
The Amplitude Analytics Unreal Engine SDK is in beta and currently supports projects targeting iOS, MacOS, or tvOS.
Unreal SDK Resources (Beta)
GitHub · Releases · Tags · API Reference
Ampli Wrapper Not Yet Available
The Ampli Wrapper is an autogenerated library based on your pre-defined tracking plan. The Ampli Wrapper is not yet available for this SDK.
SDK installation
Install the SDK plugin
Install the Unreal Engine SDK by downloading the latest version of AmplitudeUnreal.zip found on the GitHub releases page. Unzip it into a folder inside your Unreal project's Plugins directory.
mkdir -p Plugins/AmplitudeUnreal
unzip AmplitudeUnreal.zip -d Plugins/AmplitudeUnreal
Enable the SDK plugin in the editor
Open your project in the UE4 editor. Navigate to Settings > Plugins > Project > Analytics and make sure to enable AmplitudeUnreal.
screenshot of the plugin enabled
Set Amplitude as your analytics provider
Navigate to Settings -> Project Settings -> Analytics -> Providers and set the fields to Amplitude.
screenshot of the providers screen with Amplitude entered as the value
Add your API keys
Navigate to Settings -> Project Settings -> Analytics -> Amplitude and fill in the fields with your API key
screenshot of the API keys screen
Include analytics modules
In any file that involves instrumentation, you should include the necessary Unreal Engine analytics headers.
#include "Runtime/Analytics/Analytics/Public/Analytics.h"
#include "Runtime/Analytics/Analytics/Public/Interfaces/IAnalyticsProvider.h"
Usage and examples
The API of Amplitude Unreal follows the analytics provider interface defined by the Unreal Engine.
Log basic events
Events represent how users interact with your app. For example, "Game Started" may be an action you want to note.
FAnalytics::Get().GetDefaultConfiguredProvider()->StartSession();
FAnalytics::Get().GetDefaultConfiguredProvider()->RecordEvent(TEXT("Game started"));
FAnalytics::Get().GetDefaultConfiguredProvider()->EndSession();
Log events with properties
Events can contain properties. Properties give context about the event taken.
TArray<FAnalyticsEventAttribute> AppendedAttributes;
AppendedAttributes.Emplace(TEXT("Test Event Prop key1"), TEXT("Test Event value1"));
AppendedAttributes.Emplace(TEXT("Test Event Prop key2"), TEXT("Test Event value2"));
FAnalytics::Get().GetDefaultConfiguredProvider()->RecordEvent(TEXT("Game Started"), AppendedAttributes);
Set user properties
User properties help you understand your users at the time they performed some action within your app.
The generic Unreal Engine IAnalyticsProvider supports a limited number of user properties.
FAnalytics::Get().GetDefaultConfiguredProvider()->SetLocation(TEXT("Test location"));
FAnalytics::Get().GetDefaultConfiguredProvider()->SetGender(TEXT("Test gender"));
FAnalytics::Get().GetDefaultConfiguredProvider()->SetAge(TEXT(27));
Set custom user IDs
If your app has its login system that you want to track users with, use SetUserId to set a custom user ID.
FAnalytics::Get().GetDefaultConfiguredProvider()->SetUserID(TEXT("test123@test.com"));
Was this page helpful?
